ç Jeepy4x4.com :: Ver tema - BRICO --- ANULAR FUNCIONES DE JK
El sitio de los Jeep
Ir a página Anterior  1, 2, 3, 4  Siguiente
Autor Mensaje
DIABLO
MensajePublicado: 29/Dic/2009, 11:28    Título del mensaje: Responder citando
Bueno pues despues de un buen rato navegando, ya he encontrado el problema de porque no funcionan esos trucos en los modelos 2007, y es que parece ser que 1º hay que hacer una reprogramacion de la centralita que al parecer los modelos 2008 ya llevan hecha.
He encontrado este documento, pero viene en ingles, y aunque con el traductor se entiende algo, haber si hay por aqui alguno que nos lo traduzca un poco mas inteligible.
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of Chrysler LLC.
THE StarSCAN® FLASH FILES FOR THIS BULLETIN MUST BE RETRIEVED FROM
THE INTERNET.
SUBJECT:
Electronic Stability Control Disable Feature For Modified 4WD Vehicles
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Anti-Lock
Brake/Electronic Stability Module (ABS), the Cabin Control Node (CCN), and the Totally
Integrated Power Module (TIPM) with new software. Once these modules have been
reprogrammed (flashed), a sequence of steps will be required to disable or enable the
vehicle Electronic Stability Program (ESP).
MODELS:
2007 (JK) Wrangler
NOTE: This bulletin applies to Four Wheel Drive (4WD) vehicles.
DISCUSSION:
Vehicles modified with larger tires and/or suspension lifts may experience early Electronic
Stability Program (ESP) activations as compared to a non-modified production vehicle
depending on lift size/height, tire size, suspension changes and/or driving habits.
If early ESP activations are experienced while driving with a modified vehicle, the
additional ability to permanently turn off ESP is available. This ESP permanently disable
feature can be obtained once the ABS, CCN, and TIPM modules have been flashed /
reprogrammed with the correct level of software, as described in the Repair Procedure.
After completing reprogramming of the modules, an ignition switch, steering wheel and
ESP button maneuver must be performed to permanently disable ESP and to turn off the
functionality of the ESP switch. Once the ESP system is placed into permanent disable
mode, the ESP Telltale will be illuminated in the instrument cluster, and the vehicle
odometer will display a “ESP OFF” message. The ESP permanent disable feature DOES
NOT disable the vehicle Anti-Lock Brakes (ABS) or the Brake Assist System (BAS), when
the feature is implemented per this Service Bulletin Repair Procedure.
Repeating the ESP permanent disable maneuver procedure will return the system to
normal ESP operation and restore ESP switch functionality allowing for ESP ”Full”,
“Partial”, or “Off” modes.
NUMBER: 05-001-08
GROUP: Brakes
DATE: January 18, 2008
WARNING:With ESP in the permanent disabled mode, the enhanced vehicle stability
offered by the Electronic Stability Program (ESP) and Electronic Roll
Mitigation (ERM) systems is unavailable. In an emergency evasive
maneuver, the ESP and ERM systems will not engage to assist in
maintaining vehicle stability. This disabled mode is intended for off-road
use only. Vehicle modifications requiring the owner to configure the
vehicle in the ESP disabled mode, will seriously affect the vehicle
roadworthiness, safety, and may lead to loss of control and/or accident
resulting in serious injury or fatal injuries.
CAUTION: Dealer: Supply a copy of the last page of this Service Bulletin (SB) and
review copy with the vehicle owner. Store a copy of the SB last page in
the vehicle owners manual.
PARTS REQUIRED:
Qty. Part No. Description
1 04275086AB Label, Authorized Modification
SPECIAL TOOLS / EQUIPMENT REQUIRED:
NPN Battery Charger
CH9401 StarSCAN® Tool
CH9404D StarSCAN® Vehicle Cable
CH9409 StarSCAN® Documentation Kit
CH9410 StarSCAN® Ethernet Cable, 12 ft.
CH9412 StarSCAN® Software Update Device Kit
TechCONNECT PC or equivalent
REPAIR PROCEDURE - USING THE INTERNET TO RETRIEVE THE FLASH FILE:
NOTE: Before performing this Repair Procedure, the operating software in the
StarSCAN®; must be programmed with software release level 8.04 or higher.
The software release level is visible in the blue header at the top of the
StarSCAN® screen.
NOTE: The StarSCAN® diagnostic scan tool fully supports Internet connectivity.
However, to take advantage of this feature you must first configure the
StarSCAN® for your dealership's network. Make sure the StarSCAN® is
configured to the dealership's network before proceeding. For instruction on
setting up your StarSCAN® for the dealer's network refer to either:
“DealerCONNECT > Service > StarSCAN and StarMOBILE tools > Online
Documentation”, or refer to the StarSCAN® Quick Start Networking Guide.
The StarSCAN® Quick Start Networking Guide is also available on the
www.dcctools.com website under the "Download Center".
05-001-08 -2-
NOTE: StarMOBILE Desktop Client may also be used to perform this procedure.
A). Verify Current ABS, CCN, and TIPM Module Software Levels:
1. Connect the CH9404D StarSCAN® vehicle cable to the StarSCAN® and the vehicle.
2. From the “Home” screen on the StarSCAN®:
a. Select “ECU View”.
b. Touch the screen to highlight the ABS Module in the list of modules.
c. Select “More Options”.
d. Record the part number at the top of the “Flash ABS” screen for comparison and
later reference.
3. Is the ABS module software part number 52126220AC (or higher AD, AE, ...)?
The previous (old) ABS software part numbers were 52059883AD, AE, AF, or AG.
a. If YES >>> then STOP. The ABS module software DOES NOT require
reprogramming to activate the ESP disable feature. Proceed to the next step.
b. If NO >>> then the ABS module software will require reprogramming before the
ESP disable feature can be activated. Proceed to the next step.
4. Page back to the “ECU View” screen on the StarSCAN®:
a. Touch the screen to highlight the CCN Module in the list of modules.
b. Select “More Options”.
c. Record the part number at the top of the “Flash CCN” screen for comparison and
later reference.
5. Is the CCN software part number 68034990AA (or higher AB, AC, ...)?
a. If YES >>> then STOP. The CCN module software DOES NOT require
b. If NO >>> then the CCN module software will require reprogramming before the
6. Page back to the “ECU View” screen on the StarSCAN®:
a. Touch the screen to highlight the TIPM Module in the list of modules.
c. Record the part number at the top of the “Flash TIPM” screen for comparison and
later reference.
7. Is the TIPM software part number 04692287AA (or higher AB, AC, ...) or
04692173AJ (or higher AK, AL, ...)?
a. If YES >>> then STOP. The TIPM module software DOES NOT require
b. If NO >>> then the TIPM module software will require reprogramming before the
B). Download ABS, CCN, and/or TIPM Module Software From DealerCONNECT:
1. Open the hood and install a battery charger. Using a voltmeter, verify that the charging
rate provides 13.2 - 13.5 volts. Set the battery charger to continuous charge. Do not
allow the charger to time out during the flash process. Remove the charger from the
battery when the flash process is complete.
NOTE: Do not allow the charging voltage to climb above 13.5 volts during the flash
process.
2. Connect the CH9410 StarSCAN® ethernet cable to the StarSCAN® and the dealer's
network drop.
-3- 05-001-08
3. If not already performed, connect the CH9404 StarSCAN® vehicle cable to the
4. Power ON the StarSCAN®.
5. From “Home” screen select the “Flash Download” button.
6. From the “Download files from DealerCONNECT” screen select the “Next” button.
7. From the “Password” screen select “Next” button.
8. Choose VIN search. Select the “Read Info from connected vehicle” option .
9. From the “Flash Update” screen select the “Finish” button.
10. As determined earlier, if the ABS module software requires reprogramming:
a. Select “Page Back” button three (3) times to return to the “Home” screen.
b. From “Home” screen select the “Flash Download” button.
c. From the “Download files from DealerCONNECT” screen select the “Next” button.
d. From the “Password” screen select “Next” button.
e. Choose VIN search. Select the “Read Info from connected vehicle” option .
f. From the “Flash Update” screen select the “Finish” button.
g. Highlight the ABS module and select “Download To Scantool”.
h. Once the ABS download to the StarSCAN® is complete proceed to the next step.
11. As determined earlier, if the CCN module software requires reprogramming:
d. Choose VIN search. Select the “Read Info from connected vehicle” option .
e. From the “Flash Update” screen select the “Finish” button.
f. Highlight the CCN module and select “Download To Scantool”.
g. Once the CCN download to the StarSCAN® is complete proceed to the next step.
12. As determined earlier, if the TIPM module software requires reprogramming:
f. Highlight the TIPM module and select “Download To Scantool”.
g. Once the TIPM download to the StarSCAN® is complete proceed to the next step.
h. Select “Page Back” button three (3) times to return to the “Home” screen.
C). Reprogram ABS, CCN, or TIPM Modules With New Software (as required):
To Reprogram the ABS Module:
CAUTION: The ABS module may not support “abort - recovery” mode. If this flash
process is interrupted/aborted the ABS Module may be damaged beyond
repair and may require module replacement. Always verify if the module
has truly been damaged beyond repair by attempting to restart the flash
process.
1. From the “Home” screen on the StarSCAN®:
b. Touch the screen to highlight the ABS module in the list of modules.
d. Select “ECU Flash”.
e. Record the part number at the top of the “Flash ABS” screen for later reference.
f. Highlight the listed calibration that was downloaded earlier.
g. Select “Update Controller”. Follow on screen instructions.
05-001-08 -4-
h. When the update is complete, select “OK”.
i. Verify the part number at the top of the “Flash ABS” screen has updated to the new
part number.
2. Initialize the ABS module as follows:
a. Select “Back” 2 times.
b. From the ABS Overview screen, select “Misc. Functions”
c. Select “Initialize ECU”
d. Follow the on screen instructions.
3. Type the necessary information on the “Authorized Modification Label” p/n
04275086AB and attach near the VECI label (Fig. 1).
Fig. 1 AUTHORIZED MODIFICATION LABEL
1 - POWERTRAIN CONTROL MODULE P/N (INSERT P/N) USED
2 - CHANGE AUTHORITY: TSB XX-XXX-XX
3 - DEALER CODE: XXXXX
4 - DATE: XX-XX-XX
To Reprogram the CCN Module:
4. From the “Home” screen on the StarSCAN®:
b. Touch the screen to highlight the CCN module in the list of modules.
e. Record the part number at the top of the “Flash CCN” screen for later reference.
i. Verify the part number at the top of the “Flash CCN” screen has updated to the new
part number.
To Reprogram the TIPM Module:
CAUTION: The TIPM module does not support “abort - recovery” mode. If this flash
process is interrupted/aborted, the TIPM Module will be damaged beyond
repair and will require module replacement.
5. From the “Home” screen on the StarSCAN®:
b. Touch the screen to highlight the TIPM module in the list of modules.
-5- 05-001-08
e. Record the part number at the top of the “Flash TIPM” screen for later reference.
i. Verify the part number at the top of the “Flash TIPM” screen has updated to the new
part number.
NOTE: Due to the modules programming procedure, a DTC may be set in other
modules within the vehicle, if so equipped. Some DTC's may cause the MIL to
illuminate. From the “Home” screen select “System View”. Then select “All
DTCs”. Press “Clear All Stored DTCs” if there are any DTCs shown on the
list.
D). The Permanent ESP Disable Feature:
CAUTION: The dealer should instruct the vehicle owner on how to turn ON and OFF
the Permanent ESP Disable feature. If the Permanent ESP Disable feature
is desired, the customer (not the dealer) should be the responsible party
that turns the Permanent ESP Disable feature on.
CAUTION: Dealer: Supply the vehicle owner with a copy of the last page of this
Service Bulletin as reference and review copy with owner.
1. Procedure To Turn ON (or OFF) The Permanent ESP Disable Feature:
a. Verify that the automatic transmission selector is in the “Park” position, and that a
manual transmission is in neutral gear.
b. Start the vehicle engine and wait approximately five (5) seconds for the system bulb
check to complete.
c. Shift the transfer case into the 4H range position. Firmly set parking brake.
d. Turn the steering wheel until it is centered and the wheels are pointed straight
ahead.
e. Turn the steering wheel one-half (½) turn to the right (clockwise). HOLD steering
wheel in this position.
f. Press and hold the “ESP OFF” button for 7 seconds. Release the “ESP OFF” button
right after 7 seconds. Wait for chime.
g. Turn the steering wheel back to center, then turn the steering wheel one-half (½)
turn to the left (counterclockwise). HOLD the steering wheel in this position.
h. Press and hold the “ESP OFF” button for 7 seconds. Release the “ESP OFF” button
05-001-08 -6-
i. Turn the steering wheel back to center.
j. Press and hold the “ESP OFF” button for 7 seconds. Release the “ESP OFF” button
k. Cycle the ignition switch to the “OFF” position.
2. While the Permanent ESP Disable feature is turned on, the vehicle will display the
following:
a. The ESP telltale in the instrument cluster will be illuminated.
b. The vehicle odometer will display a “ESP OFF” message.
3. To Turn OFF The Permanent ESP Disable Feature:
a. Repeat the above procedure (in Step 1).
POLICY:
Information Only.
-7- 05-001-08
The Permanent Electronic Stability Program (ESP) Disable Feature:
Vehicles modified with larger tires and/or suspension lifts may experience early ESP
activations as compared to a non-modified production vehicle depending on lift size, tire
size, suspension changes and/or driving habits. If early ESP activations are experienced
while driving a modified vehicle, the additional ability to permanently turn off ESP is
available. A steering wheel/ESP button maneuver must be performed to permanently
disable ESP and defeat the functionality of the ESP switch. Repeating the procedure will
return the system to normal ESP operation and restore ESP switch functionality allowing
ESP “Partial” or “Off” modes.
Permanently disabling ESP DOES NOT disable critical vehicle systems like anti-lock
brakes (ABS) or brake assist system (BAS).
check to complete.
ahead.
g. Turn the steering wheel back to center, then turn steering wheel one-half (½) turn to
following:
3. Repeat Step 1 To Turn OFF The Permanent ESP Disable Feature.
_________________
GR Y61
Suzuki Intruder M800Z
Leon FR
Volver arriba
charly JK
MensajePublicado: 09/Ene/2010, 00:47    Título del mensaje: Responder citando
QUITAR LUZ OIL CHARGE
para quitar la luz de cambio de aceite
yo no lo e probado pero otros si y funciona
Arrow dejas la llave al punto de encendido pero con el coche apagado (no dar crank) y en un lapso de 10 segundos debes presionar el pedal del acelerador hasta el fondo tres veces. se borra el mensage de Change Oil,
Volver arriba
SPORT RED
MensajePublicado: 09/Ene/2010, 21:20    Título del mensaje: Responder citando
Change oil? en el mio no se ha encendido nunca esa luz Rolling Eyes
_________________
AGUSTIN
JK SPORT + RED
MADRID
Volver arriba
charly JK
MensajePublicado: 09/Ene/2010, 21:54    Título del mensaje: Responder citando
ami tampoco
pero por lo bisto cuando le haces tu el cambio de aceite y filtro se te enciende
ya lo probare porque el prosimo cambio de aceite y filtro se lo are yo
Volver arriba
jefena69
MensajePublicado: 15/Ene/2010, 01:48    Título del mensaje: Responder citando
traduccion del tocho de Diablo
Este boletín se suministra como información técnica y no una autorización para su reparación. Ninguna parte de esta publicación puede ser reproducida, almacenada en un sistema de recuperación,
o transmitida, en cualquier forma o por cualquier medio, sea electrónico, mecánico, fotocopia, o cualquier otro, sin el permiso escrito de Chrysler LLC.
LA StarSCAN FLASH ® FICHEROS DE ESTE BOLETÍN deben ser de recuperar
INTERNET.
ASUNTO:
Control Electrónico de Estabilidad Desactivar función para Modificado vehículos 4WD
PANORAMA GENERAL:
Este boletín trata de borrar de forma selectiva y la reprogramación de la Anti-Bloqueo
De freno / Módulo Electrónico de Estabilidad (ABS), el nodo de control de cabina (CCN), y el totalmente
Integrated Power Module (TIPM) con el nuevo software. Una vez que estos módulos han sido
reprogramados (destella), una secuencia de pasos serán necesarios para desactivar o activar la
vehículo de Programa Electrónico de Estabilidad (ESP).
MODELOS:
2007 (JK) Wrangler
NOTA: Este boletín se aplica a cuatro ruedas (4WD) vehículos.
DISCUSIÓN:
Los vehículos modificados con neumáticos más grandes y / o los ascensores de suspensión puede experimentar electrónico principios
De estabilidad (ESP) activaciones en comparación con la no modificada la producción de vehículos
dependiendo del tamaño de elevación / altura, el tamaño del neumático, los cambios de la suspensión y / o hábitos de conducción.
Si a principios activaciones ESP se experimentan durante la conducción con un vehículo modificado, el
capacidad adicional para desactivar permanentemente ESP está disponible. Esta ESP desactivar permanentemente
característica se puede obtener una vez que el ABS, CCN, y los módulos de TIPM han sido lanzados /
reprogramadas con el nivel correcto de software, como se describe en el procedimiento de reparación.
Después de completar la reprogramación de los módulos, un interruptor de encendido, el volante y los
Botón ESP maniobra se debe realizar de pesetas desactivar permanentemente y para apagar la
la funcionalidad del interruptor de pesetas. Una vez que el sistema ESP se coloca en deshabilitar permanente
modo, el Telltale pesetas serán iluminados en el panel de instrumentos, y el vehículo de
cuentakilómetros mostrará una "ESP OFF" de mensajes. El NO permanente ESP inhabilitar la función
NO desactivar el vehículo ABS (ABS) o el sistema de asistencia en la frenada (BAS), cuando
la función se lleva a cabo por este Servicio de reparación Boletín Procedimiento.
Repetir el procedimiento permanente ESP maniobra de desactivar el sistema volverá a
ESP operación normal y restaurar la funcionalidad que permite cambiar de pesetas de pesetas "completo",
"Parcial", o "No" modos de transporte.
NÚMERO: 05-001-08
Grupo: Frenos
FECHA: 18 de enero 2008
ADVERTENCIA: Con el ESP en el modo de discapacidad permanente, la estabilidad del vehículo mayor
ofrecidos por el Programa Electrónico de Estabilidad (ESP) y Electronic Roll
De mitigación (MTC), los sistemas no está disponible. En caso de emergencia evasiva
maniobra, los sistemas ESP y el MTC no se dedicará a ayudar a
mantenimiento de la estabilidad del vehículo. Este modo está diseñado para personas de movilidad reducida fuera de la carretera
uso. Modificaciones que requiere el propietario del vehículo para configurar el
vehículo en el modo de pesetas con discapacidad, tendrá graves repercusiones en el vehículo
la inspección técnica, la seguridad, y puede conducir a la pérdida de control y / o accidente
que resulta en lesiones graves o accidentes mortales.
PRECAUCIÓN: Distribuidor: Suministro de una copia de la última página de este Boletín de Servicio (SB) y
copia de revisión con el propietario del vehículo. Guarde una copia de la SB en la última página de
los propietarios de vehículos manual.
Partes Requeridas:
CANT. Parte No. Descripción
1 04275086AB Label, autorizado Modificación
HERRAMIENTAS ESPECIALES / EQUIPO NECESARIO:
NPN Battery Charger
CH9401 StarSCAN ® Herramienta
CH9404D StarSCAN ® cable de vehículo
CH9409 StarSCAN ® Kit de documentación
CH9410 StarSCAN ® Ethernet Cable, 12 pies
CH9412 StarSCAN ® Kit de actualización de software del dispositivo
PC TECHCONNECT o equivalente
Procedimiento de reparación - Usar el Internet para recuperar el archivo de FLASH:
NOTA: Antes de realizar este procedimiento de reparación, el software que operan en el
StarSCAN ®, debe de ser programado con el nivel de lanzamiento de software 8.04 o superior.
El nivel de versión del software es visible en la cabecera azul en la parte superior de la
StarSCAN pantalla ®.
NOTA: El StarSCAN ® herramienta de análisis de diagnóstico totalmente compatible con la conexión a Internet.
Sin embargo, para tomar ventaja de esta característica, debe configurar el
StarSCAN ® para la red de la concesionaria. Asegúrese de que el StarSCAN ® es
configurado para la red de distribución antes de proceder. Para obtener instrucciones sobre
la configuración de su StarSCAN ® para la red del distribuidor referirse a:
"DealerCONNECT> Servicio> StarSCAN y herramientas StarMOBILE> Online
Documentación ", o se refieren a la StarSCAN ® Quick Start Networking Guide.
El StarSCAN Quick Start ® Guía de redes también está disponible en la
www.dcctools.com sitio web bajo el "Centro de descargas".
05-001-08 -2 --
NOTA: StarMOBILE cliente de escritorio también puede ser utilizado para realizar este procedimiento.
A). Verificar actual ABS, CCN, y TIPM software del módulo Niveles:
1. Conecte el cable de StarSCAN CH9404D ® vehículo a la StarSCAN ® y el vehículo.
2. Desde la "Casa" en la pantalla StarSCAN ®:
a. Seleccione "ecu" Ver ".
b. Toque la pantalla para resaltar el módulo de ABS en la lista de módulos.
c. Seleccione "Más opciones".
d. Anote el número en la parte superior de la pantalla de "Flash ABS" para la comparación y la
después de referencia.
3. Es el módulo de software de parte de ABS número 52126220AC (o superior AD, AE, ...)?
La anterior (de edad) los números de ABS de software fueron 52059883AD, AE, AF, o AG.
a. Si es Sí>>> luego STOP. El módulo de ABS de software NO requiere
la reprogramación para activar la función ESP desactivar. Continúe con el paso siguiente.
b. Si NO>>> entonces el software ABS módulo requiere una reprogramación antes de la
Característica se puede desactivar el ESP activado. Continúe con el paso siguiente.
4. Volver a la página "ecu" Ver "en la pantalla StarSCAN ®:
a. Toque la pantalla para resaltar el módulo de CCN en la lista de módulos.
b. Seleccione "Más opciones".
c. Anote el número en la parte superior de la pantalla de "Flash CCN" para la comparación y la
5. Es la parte de software CCN número 68034990AA (o superior AB, AC, ...)?
a. Si es Sí>>> luego STOP. El módulo de software CCN NO requiere
b. Si NO>>> entonces el módulo de software CCN será necesario antes de la reprogramación de
6. Volver a la página "ecu" Ver "en la pantalla StarSCAN ®:
a. Toque la pantalla para resaltar el módulo de TIPM en la lista de módulos.
c. Anote el número en la parte superior de la pantalla de "Flash TIPM" para la comparación y la
7. Es la parte de software TIPM número 04692287AA (o superior AB, AC, ...) o de
04692173AJ (o superior AK, AL, ...)?
a. Si es Sí>>> luego STOP. El módulo de software TIPM NO requiere
b. Si NO>>> entonces el software TIPM módulo requiere una reprogramación antes de la
B). Descargar ABS, CCN, y / o TIPM software del módulo de DealerCONNECT:
1. Abra el capó y de instalar un cargador de batería. Usando un voltímetro, compruebe que la imputación
tasa proporciona 13,2 a 13,5 voltios. Establezca el cargador de batería a carga continua. No
permitir que el cargador de tiempo durante el proceso de flash. Retire el cargador de la
de la batería cuando el proceso de flash está completa.
NOTA: No permita que el voltaje de carga para subir por encima de 13,5 voltios durante el flash de
proceso.
2. Conecte el cable de StarSCAN CH9410 ® Ethernet para el StarSCAN ® y el comerciante
caída de la red.
-3 - 05-001-08
3. Si no está ya realizado, conecte el cable StarSCAN CH9404 ® vehículo a la
4. Encienda el StarSCAN ®.
5. De "pantalla de inicio" seleccione la opción "Flash Descargar".
6. Desde la "Descarga de archivos desde la pantalla DealerCONNECT", seleccionar el botón "Siguiente".
7. Desde la pantalla de "Contraseña", seleccione "Siguiente".
8. Elija VIN de búsqueda. Seleccione la Información "Leer del vehículo conectado" opción.
9. Desde la pantalla de "Flash Update", seleccionar el botón "Finalizar".
10. Como se determinó anteriormente, si el software del ABS módulo requiere una reprogramación:
a. Seleccione "Página Atrás" de tres (3) veces para volver a la pantalla de "Inicio".
b. De "pantalla de inicio" seleccione la opción "Flash Descargar".
c. Desde la "Descarga de archivos desde la pantalla DealerCONNECT", seleccionar el botón "Siguiente".
d. Desde la pantalla de "Contraseña", seleccione "Siguiente".
e. Elija VIN de búsqueda. Seleccione la Información "Leer del vehículo conectado" opción.
f. Desde la pantalla de "Flash Update", seleccionar el botón "Finalizar".
g. Resalte el módulo de ABS y seleccione "Descargar Para Scantool".
h. Una vez que la descarga de ABS a la StarSCAN ® es completa proceder al siguiente paso.
11. Como se determinó anteriormente, si el software CCN módulo requiere una nueva programación:
d. Elija VIN de búsqueda. Seleccione la Información "Leer del vehículo conectado" opción.
e. Desde la pantalla de "Flash Update", seleccionar el botón "Finalizar".
f. Resalte el módulo de CCN y seleccione "Descargar Para Scantool".
g. Una vez que la descarga CCN a la StarSCAN ® es completa proceder al siguiente paso.
12. Como se determinó anteriormente, si el software TIPM módulo requiere una nueva programación:
f. Resalte el módulo TIPM y seleccione "Descargar Para Scantool".
g. Una vez la descarga TIPM a la StarSCAN ® es completa proceder al siguiente paso.
h. Seleccione "Página Atrás" de tres (3) veces para volver a la pantalla de "Inicio".
C). Reprogramar ABS, CCN, o TIPM módulos con Nuevo Software (según proceda):
Para reprogramar el módulo de ABS:
PRECAUCIÓN: El módulo de ABS no puede apoyar "abortar - Recuperación modo". Si este flash
proceso se interrumpe / abortó el módulo de ABS pueden ser dañados más allá de
la reparación y podrá exigir la sustitución del módulo. Siempre verifique si el módulo
realmente ha sido dañado irreparablemente al intentar reiniciar el flash
proceso.
1. Desde la "Casa" en la pantalla StarSCAN ®:
d. Seleccione "ECU Flash".
e. Anote el número en la parte superior de la pantalla de "Flash ABS" para referencia posterior.
f. Resalte la calibración de la lista que se ha descargado antes.
g. Seleccione "Actualizar controlador". Siga las instrucciones en pantalla.
05-001-08 -4 --
h. Cuando se complete la actualización, seleccione "Aceptar".
i. Verificar el número de pieza en la parte superior de la pantalla de "Flash ABS" se ha actualizado a la nueva
número de parte.
2. Inicializar el módulo de ABS como sigue:
a. Seleccione "Atrás": 2.
b. En la pantalla de sistema ABS, seleccione "Misc. Funciones "
c. Seleccione "Iniciar ecus"
d. Siga las instrucciones en pantalla.
3. Escriba la información necesaria sobre la "p autorizado Modificación Label" / n
04275086AB y adjuntar cerca de la etiqueta de VECI (Fig. 1).
Fig. 1 LABEL MODIFICACIÓN AUTORIZADA
1 - Control del Tren de módulo P / N (P INSERT / N) utilizados
2 - Autoridad CAMBIO: TSB XX-XXX-XX
3 - CÓDIGO DE DISTRIBUIDOR: XXXXX
4 - FECHA: XX-XX-XX
Para reprogramar el módulo de CCN:
4. Desde la "Casa" en la pantalla StarSCAN ®:
b. Toque la pantalla para resaltar el módulo de CCN en la lista de módulos.
e. Anote el número en la parte superior de la pantalla de "Flash CCN" para referencia posterior.
i. Verificar el número de pieza en la parte superior de la pantalla de "Flash CCN" se ha actualizado a la nueva
número de parte.
Para reprogramar el módulo de TIPM:
PRECAUCIÓN: El módulo de TIPM no admite "abortar - Recuperación modo". Si este flash
proceso se interrumpe / abortados, el Módulo de TIPM será dañado más allá de
la reparación y requerirá la sustitución del módulo.
5. Desde la "Casa" en la pantalla StarSCAN ®:
b. Toque la pantalla para resaltar el módulo TIPM en la lista de módulos.
-5 - 05-001-08
e. Anote el número en la parte superior de la pantalla de "Flash TIPM" para referencia posterior.
i. Verificar el número de pieza en la parte superior de la pantalla de "Flash TIPM" se ha actualizado a la nueva
número de parte.
NOTA: Debido al procedimiento de programación de módulos, un DTC se puede establecer en otros
módulos dentro del vehículo, si está equipado. Algunos DTC puede causar a la MIL
iluminar. Desde la pantalla de "Inicio", seleccione "Sistema" Ver ". A continuación, seleccione "Todos los
DTC ". Pulse "Borrar todos los DTC almacenados" si hay alguna muestra en la CDI
lista.
D). La Permanente Deshabilitar ESP Característica:
PRECAUCIÓN: El concesionario deberá instruir al propietario del vehículo sobre la manera de encender y apagar
la función ESP Permanente Deshabilitar. Si la función ESP Permanente Desactivar
se desea, el cliente (no el concesionario) debe ser la parte responsable
que convierte a la característica permanente de pesetas en Deshabilitar.
PRECAUCIÓN: Distribuidor: Suministro el propietario del vehículo con una copia de la última página de este
Boletín de Servicio como referencia y copia de revisión con el propietario.
1. Procedimiento activar (o desactivar) la Permanente Deshabilitar ESP Característica:
a. Compruebe que el selector de la transmisión automática está en la posición "Park", y que un
transmisión manual se encuentra en punto muerto.
b. Arranque el motor del vehículo y esperar aproximadamente cinco (5) segundos para el sistema de bombilla
verificación para completar.
c. Cambie la caja de transferencia en la posición de la gama de 4H. Firmemente el freno de mano.
d. Gire el volante hasta que esté centrado y las ruedas están apuntando hacia el
por delante.
e. Gire el volante de la mitad (½), gire a la derecha (sentido horario). HOLD de dirección
rueda en esta posición.
f. Mantenga pulsado el "ESP OFF" botón durante 7 segundos. Suelte el "ESP OFF" botón
justo después de 7 segundos. Espere para el timbre.
g. Girar el volante hacia el centro, a continuación, girar el volante a la mitad (½)
gire a la izquierda (sentido antihorario). Sostenga el volante en esa posición.
h. Mantenga pulsado el "ESP OFF" botón durante 7 segundos. Suelte el "ESP OFF" botón
05-001-08 -6 --
i. Gire el volante hacia el centro.
j. Mantenga pulsado el "ESP OFF" botón durante 7 segundos. Suelte el "ESP OFF" botón
k. Ciclo de la llave de encendido en OFF la "posición".
2. Si bien la función ESP Permanente Deshabilitar está encendido, el vehículo se mostrará el
siguientes:
a. El ESP indicadoras en el panel de instrumentos se iluminará.
b. El cuentakilómetros del vehículo se mostrará una "ESP OFF" de mensajes.
3. Apagar la Permanente Deshabilitar ESP Característica:
a. Repita el procedimiento anterior (en el paso 1).
POLÍTICA:
Sólo información.
-7 - 05-001-08
La Permanente electrónico de estabilidad (ESP) Deshabilitar características:
Los vehículos modificados con neumáticos más grandes y / o los ascensores de suspensión puede experimentar ESP principios de
activaciones en comparación con la no modificada la producción de vehículos dependiendo del tamaño del ascensor, neumáticos
tamaño, los cambios en la suspensión y / o hábitos de conducción. Si se siente principios de activaciones de pesetas
mientras se conduce un vehículo modificado, la capacidad adicional de desactivar permanentemente ESP es
disponible. Un volante / ESP botón maniobra se debe realizar de forma permanente
ESP deshabilitar la funcionalidad y la derrota del interruptor de pesetas. Repetir el procedimiento se
devolver el sistema a la operación normal de pesetas y restaurar la funcionalidad que permite cambiar de pesetas
ESP "Parcial" o "Desactivar" modos de transporte.
Provoca incapacidad permanente ESP no desactiva los sistemas de vehículos críticos como anti-bloqueo
frenos (ABS) o el sistema de asistencia a la frenada (BAS).
por delante.
g. Gire el volante hacia el centro, luego gire el volante de la mitad (½) a su vez,
siguientes:
3. Repita el paso 1 para apagar el Featur Permanente ESP Desactivar
_________________
EX XJ 4.0
Volver arriba
juanitowrangler
MensajePublicado: 24/Feb/2010, 12:17    Título del mensaje: Responder citando
hola, alguien sabe como se anulan los sensores de presion de las ruedas?
Acabo de montar las llantas y ruedas nuevas y claro las otras las dejo para pasar itv y las valvulas de las nuevas son ormales, entonces se me queda el chivato de presion de neumaticos encendido, alguien sabe como anularlo?
GRACIAS
Volver arriba
TitoRubicon
MensajePublicado: 08/May/2010, 09:13    Título del mensaje: Responder citando
GRACIAS
Un poco de cinta aislante encima de la luz y listo, Laughing Laughing Laughing estilo homer simpson. Mr. Green
Lo cierto es que no lo se, pero... podias probar a montar las otras valvulas (Las originales) en las nuevas llantas, Wink
_________________
WRANGLER!!!
Volver arriba
lobix
MensajePublicado: 08/May/2010, 22:24    Título del mensaje: Responder citando
Como dice Tito...la solución es montar las válvulas en las nuevas llantas...Venden estás válvulas en la Jeep...no creo que sean caras..
Por cierto, si las pides, pídeme una que me salió disparada de la llanta el día del incidente... Rolling Eyes
Aunque si se logra adivinar cómo engañar el sensor, mejor, pq son muy rígidas y fácil de romper...me gustan más las de goma o silicona...son flexibles a los golpes... Wink
_________________
Volver arriba
Haigelin
MensajePublicado: 08/May/2010, 22:32    Título del mensaje: Responder citando
charly JK escribió:
ami tampoco
Yo he hecho el cambio de aceite y a mi no me ha salido ese aviso en 42000km. Sad
_________________
http://subefotos.com/ver/?2bda6c8292ea75a609113641b28e0532o.jpg
http://subefotos.com/ver/?736705ad662c262bce7558736944318bo.jpg
Volver arriba
Raulito
MensajePublicado: 08/May/2010, 22:57    Título del mensaje: Responder citando
Puess eso de que no creo que sean caras ,te equivocas,55€ cada una Shocked osea que x4 =220€
_________________
http://www.club4x4costatropical.es.tl
Jeep Wrangler JK Sport BocaNegra 2
wv cc tdi
Volver arriba
Ver perfil del usuario Enviar mensaje privado Enviar correo Visitar sitio web del autor MSN Messenger
TitoRubicon
MensajePublicado: 09/May/2010, 15:51    Título del mensaje: Responder citando
yo llevo una medio rota, le falta la mitad de la rosca, tengo un invento pa remediarlo, ya pedi presupuesto de una, son 50 lereles, y me dijo el de la concesion que havia que meter el ordenador pa configurarla nueva valvula, una solicion lobix es ke montes la llanta de repuesto pero cambiando las gomas.
PD: una valvula de goma 2€, quitar el indicador de presion? Shocked
_________________
WRANGLER!!!
Volver arriba
Raulito
MensajePublicado: 09/May/2010, 18:06    Título del mensaje: Responder citando
Yo tambien llevaba uan medio rota y como salia demasiado caro comprar todo junto pues cuando monte las ruedas nuevas monte en sustitucion de la rota una de goma y como el indicador de presion se puede separar de la valvula la pege en la llanta con cinta de doble cara Rolling Eyes y funciona igual que antes Mr. Green
_________________
wv cc tdi
Volver arriba
lobix
MensajePublicado: 09/May/2010, 21:41    Título del mensaje: Responder citando
Joder con las válvulas........mejor buscar el brico de anular el disppositivo... Mr. Green
_________________
Volver arriba
xato
MensajePublicado: 10/May/2010, 08:35    Título del mensaje: Responder citando
HAIGELIN escribió:
charly JK escribió:
ami tampoco
yo tambien he hecho el cambio de aceite, ya dos veces y a mi tampoco me ha salido este aviso Rolling Eyes
_________________
sahara 2p.
AFN delantero y trasero
golden winch 4500kg.
emisora president.
para mis ratos libres 2 KTM 200EXC Y 450EXC.
Volver arriba
xato
MensajePublicado: 10/May/2010, 08:37    Título del mensaje: Responder citando
pues si lobix mejor quitar el dispositivo Crying or Very sad Embarassed Crying or Very sad
_________________
sahara 2p.
emisora president.
Volver arriba
Mostrar mensajes anteriores:
Página 2 de 4
Saltar a:
No puede crear mensajes
No puede responder temas
No puede editar sus mensajes
No puede borrar sus mensajes
No puede votar en encuestas
